Pto carrier bearing question
Chad Penny
05-10-2002 09:55:03
I have a WD-45 and I need to replace the pto shaft. I got it out the gear box and out of the tractor. How do you get the pto carrier bearing off. What I mean by carrier bearing I am talking about the bearing that holds it up in the back of the tractor. Does it just get pressed off the pto shaft or do you need to remove the seals and remove a "c" clip or something? Please help a.s.a.p. if at all possible.
Chad Penny
L Hud
05-10-2002 12:20:07
 Re: pto carrier bearing question in reply to Chad Penny, 05-10-2002 09:55:03
There are clips that hold the bearing in the carrier. Remove the seals and then the clips and the bearing should come out. The bearing is a press on the shaft. Should knock off easily with a hammer and a pipe. Hope this helps
L Hud
