B
zac
05-09-2002 20:30:19
I have a 1939 model b. There is a piece of angle iron on the back between the two fenders (its a rear seat bracefor a cusion seat)However It supports a wood floor and has a pan seat. Is there any chance any of this is original? Also will a motor off a 1948 B work on a 1941 C? The only difference I saw was the number of studs coming through the valve cover the 48 has 4 and the 41 has 2. Thanks Zac
steve
05-10-2002 20:14:55
 Re: b in reply to zac, 05-09-2002 20:30:19
the motors are interchangable. as you said, they changed the number of vavle cover studs, etc, so some individaual parts will be a little different, but the entire engine can be changed out.
----the original seat was an angle iron frame, maybe 1.5 inch angle? that was fender to fender and maybe 18inches front to back. there was a cushion seat that sat on top. after the B and C series, they made the CA and it had a pan type seat. some people have taken the pan off a CA or WD and installed them on the B and C tractors. You r B and C tractors originally both had bench (cushion) seats. their fenders are a little different.
