Please read this and reply with help.
Chris
05-08-2002 14:11:20
I need to know what the firing order of the spark plugs such as 1432 for a 1949 Allis Chalmers model g is? Where is the number 1 plug....near the radiator or the back end of the tractor? Finally, where is the number 1 plug on the distributor cap?
Thanks
DanD.
05-08-2002 14:20:13
 Re: Please read this and reply with help. in reply to Chris, 05-08-2002 14:11:20
The firing order on a G is 1342. #1 is away from the flywheel which in the case of the G is to the rear. I don't know off hand which hole on the distributor was originally #1. It could be any depending on how it was last reinstalled. To check, remove the spark plugs so you can turn the engine over easily by pushing the tractor or using the hand crank. Hold your finger over #1 spark plug hole until the air is being forced out which means that #1 is the next cylinder to fire. Now, pop the cover off the distributor and look to see which is the next hole the rotor is going to be pointing to. The will be #1, then just go 1342 in the clockwise direction.
