Aerosol paint for wheel rims?
Farmer Brown
05-08-2002 08:30:28
Anyone have any recommendations for what kind of primer and top coat to use to paint WD rear wheel rims?
I am getting new tires and will be having the rims sand blasted while the tires are off as they are getting rusty. I want to repaint,but do not have a paint sprayer, am thinking about trying to use aerosol cans. Is this a bad idea?
Rod (NH)
05-08-2002 09:32:32
 Re: aerosol paint for wheel rims? in reply to Farmer Brown, 05-08-2002 08:30:28
NO...it's not a bad idea...but: Rather than use the typical aerosol paints, I recommend you consider the Preval unit in the link. It is relatively inexpensive and would permit you to use a high quality, two component, epoxy primer. Since you are going to the trouble of providing a top notch surface preparation by blasting, I think you would be far better off using the two part epoxy than any kind of primer that you can get in a rattle can.
For primer, about the best you can get (IMO) is DPLF by PPG. PPG also has an OMNI line that is less expensive. That epoxy would be OMNI MP170. Both of these are two part primers requiring a catalyst. They contain no isocyanates so you don't have to be concerned with that safety issue. Although the DPLF is more expensive on a unit basis, it is available in quarts. As I recall, the MP170 is only available in gallons so you might be better off with the DPLF, even though it is more expensive...that is unless you have more to do than just the rims.
Whatever you choose, make sure you prime the rims right after blasting. Immediately would be preferable. Just humidity in the air can begin the rusting process on steel that is in that raw a state. Also if you use the epoxy primer, make sure you topcoat shortly thereafter...3 days maximum for the OMNI and a week maximum for the DPLF. Otherwise, you should scuff sand and reprime.
Rod
Chris
05-09-2002 10:56:01
 Re: Re: aerosol paint for wheel rims? in reply to Rod (NH), 05-08-2002 09:32:32
You're right about the bare steel rusting immediately. But to prevent this and to prep the surface for primer you should etch the metal. Some epoxy primers are self etching but it doesn't hurt, especially if it's a humid day or you don't paint immediately. You can purchase the etching solution where you get the 2 part epoxy primer. I get mine at an auto body paint supply store. I can't quote any product #s for you, just ask for metal etching stuff.
Dave Grubb
05-08-2002 09:01:49
I understand that the rear rims were actually galvanized and not painted. I see some of the guys are using a dull aluminum paint on the rims for a close color match. I have seen spray cans of cold galvanize in the welding supply shops used for coating over weld repairs. I haven't tried the stuff but it might be worth looking in to. I would try to mount the wheel on a couple of roller stands like those used for the out feed side of a table. Then have someone slowly turn the wheel while you keep the spray can directed as necessary.
Steve in N.J.
05-08-2002 17:42:13
 Re: Re: aerosol paint for wheel rims? in reply to Dave Grubb, 05-08-2002 09:01:49
Farmer Brown,
After cleaning my rear wheels up on my B, I used a can of Rustoleum "Stainless Steel" in an aerosol can. Picked it up in Home Depot. Pretty tall can, so I had plenty for both wheels. I was pretty impressed the way it came out when I stood the newly painted wheel next to the other that wasn't done yet. Darn near matched the old galvanized look! Can't tell ya how it's gonna last yet, I only just got the new engine fired and haven't had it out yet... Might be somthin' to try..... Steve B.
