B/c
zac
05-07-2002 18:23:04
can any one tell me the difference between a b and c final drive, thanks
steve
05-07-2002 19:43:58
 Re: b/c in reply to zac, 05-07-2002 18:23:04
the top shaft (axle) is about 6 inches shorter on the B, and the housing is also 6 inches shorter (12 inches different width between the wheels). The C usually has a bull gear shaft with a built on 5 bolt hub for the wheel (5 lug nuts). The B has a hub that presses on tapered splines and has a "BIG" retaining nut on the outside. I believe the gear ratios are slightly different and probably can not match up a top shaft from one and a bull gear from the other.
