Re: WD45 TRANS CLUTCH NOISE?
Tom
05-07-2002 16:38:36
They do make a bang when releasing. You can adjust the pressure with shims between the clutch cover and the part it bolts to. I don't know thenames of the parts without looking in my books. It should be obvious where the shims are if you look. They are under the six (3 pairs of 2) bolts that hold the clutch together. Even with a limp feel the clutch may hold and work, they are over built, a hard pull isn't necessary to engage them, should be firm. Repair manual would help you , you should have one anyway.
Tom Miller
05-08-2002 14:57:20
 Re: Re: WD45 TRANS CLUTCH NOISE? in reply to Tom, 05-07-2002 16:38:36
I just adjusted the clutch in my 45, and it has the same snap that yours has. I was worried for a little while, but i got over it.
