Opinions on AC D19
Errin OH
05-07-2002 10:39:43
Went and looked at a D19 w/6c gas and cab. Looks rough at first but actually it pretty straight with mostly surface rust. Started and ran just fine. Tires are kinda weak (30%) and needs one front rim (rusting out around valve stem) but holding pressure. The only concern I have is a gear noise between the engine and the front of the tranny. In neutral no noise, engage PTO - noise. Engage gears - noise. Sounds a lot like chain slop (singing and ticking). Any clues as to what it could be. I don't think its the throw out bearing, seems a little further back. Price seems right for a working tractor of its condition.
alliscdave
05-07-2002 16:16:52
 Re: Opinions on AC D19 in reply to Errin OH, 05-07-2002 10:39:43
My D19 does the same thing. The local Allis dealer told me that it is the hydrolic pump, there is a roller-rocker that rides on a cam lobe. When you step on the clutch the noise stops. He said that there is nothing to worry about. It is just from moderate wear. Some tractors stop making the noise after they warm up.
Errin OH
05-08-2002 07:59:39
 Re: Re: Opinions on AC D19 in reply to alliscdave, 05-07-2002 16:16:52
Thanks Dave, now that you mention it, I didn't noticed until they showed me that the Hyd worked.
Errin
