D17 BRAKES
DAVE
05-07-2002 02:27:55
I am having trouble getting the top pin out of the transmission housing that holds the top of the brake shoes. The manual says to pry it out. I think it must have been printed when the tractor was 1 year old. Other side came right out. have cautiously applied heat, but do not know how far to go, do not want to hirt housing. How about it Dewey, what do i do?
Craig MO
05-07-2002 20:34:51
 Re: D17 BRAKES in reply to DAVE, 05-07-2002 02:27:55
You can try heating pin and housing then put cold water on just the pin and see if it will budge. If your going to replace the bands and not reline them cut the bands at the pin an get a pipe wrench or good pair of vise grips to turn the pin after the bands are off. I have had to cut the pin and drive the outer portion in to loosen then take the two pieces out with visegrips.
Dave
05-08-2002 18:01:18
 Re: Re: D17 BRAKES in reply to Craig MO, 05-07-2002 20:34:51
Thanks Craig. We just got it out had to cut the brake bands off, Heated it enough with a torch to get it to budge. Then we cut the center of the pin out, drove the outerside through and pulled the inner piece out with vicegripes. Sounds like you have been through this before.
greg
05-21-2002 18:36:16
 Re: Re: Re: D17 BRAKES in reply to Dave, 05-08-2002 18:01:18
Likewise, I have had to do same. Cut, drive, and twist inner end out. Don't be bashful.
