WD45 Engine Block
Mike
05-06-2002 06:28:21
Looks like I may have a crack in my WD45 Block. Lots of water mixed with the oil. Does anyone have a fix or a known good replacement?
Duey (IA)
05-06-2002 17:35:31
 Re: WD45 Engine Block in reply to Mike, 05-06-2002 06:28:21
Mike,
Before you jump the gun, check to be sure it's really cracked. There is a possibility it is a sleeve O-ring that is leaking !!! Duey
Mike
05-07-2002 05:55:24
 Re: Re: WD45 Engine Block in reply to Duey (IA), 05-06-2002 17:35:31
Further investigation revealed a crack between the 3rd and 4th sleeve at the bottom.
Ron
05-06-2002 12:04:31
I doubt there are many that are not cracked between the sleeves of #1&2....the web is very narrow there..... Many folks ask the same question -----YES, if this is where it is cracked, it can be repaired by puting a cross-bolt in the block, between the sleeves--or having it resistance-welded..... Some just pour thick OLD Paint in the bottom of the cleaned, assembled water jacket.... Hope this helped..!! Ron.
Mike
05-07-2002 06:01:06
 Re: Re: WD45 Engine Block in reply to Ron, 05-06-2002 12:04:31
The crack is between the 3rd and 4th sleeve at the bottom. Local machine shop thinks something like jb weld should seal. Would you take the chance?
Ron
05-07-2002 15:58:03
 Re: Re: Re: WD45 Engine Block in reply to Mike, 05-07-2002 06:01:06
Nope.
You should have as much room between them as the #1 & 2..... .. Pin it....
