Allis-Chalmers G
Johnny Cook
05-05-2002 12:44:32
Having trouble with trans. hanging up between gears. Can anyone help?
david
05-07-2002 09:35:58
 Re: Allis-Chalmers G in reply to Johnny Cook, 05-05-2002 12:44:32
This is a common problem with alot of old ACs. I have my shifting plate and gear shifter at a machinist as I type this. You probably want to take your shifter plate off and your gear shift out and inspect for wear. What happens is that the bracket that guides the shifter between forks gets
worn along with the ball on the end of your shifter. This will cause extra space between shifting which causes the hang-ups. You may soon even experience engaging 2 gears at once. That is what mine was doing, leaving the 2nd and 3rd gear fork in gear without shifting the fork to the nuetral position, and allowing me to shift to the 1st and 2nd gear fork. Your shifting plate has 4 bolts just behind the battery box. You'll have to remove a couple of pins and slide the right brake arm off. Your shifter will have a retaining ring and a guide ring. Once removed you can pull the gear shifter right out. mind you that you have 2 small pins that guide the shifter at the shifter boot area. Don't drop them into the trans. Make sure the ball on the end of your gear shift is not to worn, if so take it to a machinist along with your shifting plate and have any wear built back up to get a nice semi tight shifting guide. Good luck.
