WD hydraulic fluid level
Gregory K. Sode
05-03-2002 20:13:00
My WD always seems to show milky on the hydraulic dipstick. I fill it to the correct level on the dipstick but it always seems to be low when I check it sometime later. The hydraulic system works good. It lifts and lower all my 3 point attachments fine. Any ideas on why it seems to always need more? It doesn't seem to be leaking anywhere. Also, why the moisture? Thanks!
DJ
05-04-2002 07:17:55
 Re: WD hydraulic fluid level in reply to Gregory K. Soderberg, 05-03-2002 20:13:00
Check the oil level behind it(transmission clutch). It's probably getting higher. There is a seal in between that is probably leaking.
