Carburetor flooding
Gregory K. Sode
05-03-2002 20:09:01
I've had the Marvel Schebler Carb on my wd overhauled because it often dripped when I shut off the motor. It still does it sometimes. What can be done?
Larry
05-07-2002 16:55:35
 Re: carburetor flooding in reply to Gregory K. Soderberg, 05-03-2002 20:09:01
I agree with Brian. Trash, especially rust, either in the tank or the carb, should be the first thing you look for in flooding or starving.
markp
05-06-2002 19:14:15
when you clean your carb take the seat out where the needle goes. there is a good possibility that rust has collected on top of that seat. I had to rebuild my marvel carb yesterday and it looked clean until i took the seat out. I found alot of rust and after I blew the line out it worked fine. hope this helps
Craig MO
05-03-2002 20:43:51
The gas is coming past the needle and seat. Check the float level and make sure its correct, you should have gotten a guage with your kit I think its 1/4 inch. Make sure your fuel system is clean. No sediment floating around. Make sure you have a screen in the sedimemt bowl. If you have a solid steel needle you might want to get one this neoprene. Make sure that seat is screwed securely into the base.
JMS/MN
05-03-2002 20:42:55
Could be that the float is out of adjustment. The literature with the rebuild kit should explain how to measure for the proper clearance, and how to bend the mounting to achieve that measurement.
Bryan Smith
05-06-2002 06:07:47
 Re: Re: carburetor flooding in reply to JMS/MN, 05-03-2002 20:42:55
And just a tiny bit of rust in the gas tank will find its way through the screen or strainer ancd cause this repeatedly. I had this problem until I installed an in-line fuel filter. I cleaned the carb and have had no problems since.
