Talk to craig mo on subject hyd. for 175 Allis
J.T. Hale
05-03-2002 03:21:45
cc.Craig,tractor,s loader jerk,s when lifting up, same thing when i use 3pt.Oil level is full,some of the cylinder,s leak . It just started this looking for simple over looked cure.Maybe hyd. filter need,s changed?
Craig MO
05-03-2002 19:40:32
 Re: talk to craig mo on subject hyd. for 175 Allis in reply to J.T. Hale, 05-03-2002 03:21:45
The two things I would check first are your suction line and screen. The suction screen located in the bottom of torque tube can become sluged over or partly plugged with foreign material. The other thing is your suction line. Look for air to enter system at flange where line comes out of torque tube .The other would be where line goes on to pump. It sounds to me like you pump is cavating. Let me know if you have already checked these and we will look for other posibilities.
