Wd 45 locking loader up?
Shawn
05-02-2002 11:14:21
On my wd 45 I want to put the plow on but I have the loader on. Is there a way I can lock the loader up so I an use the back end? Can I just change the pump. I have had the loader stay up when I didn't put the screw in all the way so it slid instead of moving the piece.
Tom
05-02-2002 15:54:56
 Re: wd 45 locking loader up? in reply to Shawn, 05-02-2002 11:14:21
Shawn, What I would suggest is that you purchase a on/off hydraulic valve and install it between your loader and the pump. When you want to leave the loader up so you can use the snap-coupler or remote outlet, just raise the loader to the desired height and turn the valve off. This traps oil in the loader cylinders. We did this on ours until we installed a live pump on the crankshaft. Tom
