Re: wd 45 over heating
Dan Dooley
05-01-2002 02:48:31
If all else is right then the block is full of rust and sludge and it is going to overheat. Don't make a dam if the rad is full of fluid, if the block is full of rust..... check to find the capacity of the cooling system and then see if that is how much is in the system .....if it is short, then clean out your block ..... through a freeze plug.
