Difference between B and C?
James (MO)
04-29-2002 19:24:14
How does a person tell the difference between a B and a C? I see some of these at swap meets and local antique tractor shows, but don't have a clue how to indentify them. I don't even know where to look for a serial number. My knowledge is limited to CA, WD, WD-45, and WC. Thanks...James
joe
04-30-2002 04:36:37
 Re: difference between B and C? in reply to James (MO), 04-29-2002 19:24:14
One has a letter "B" on the side of the radiator cowl and the other has the letter "C" in the same spot. Hope this helps! LOL!
steve
04-29-2002 19:59:26
both tractors use the same radiator, engine, transmission. there are a few things that might help to distinguish, but you run into tractors that are a combinations of both the B and C.
--most Bs are wide front end, most Cs are narrow front.
--the serial number is stamped by the transmission shift lever on the case.
--the steering arm on the steering box of a B points down. The steering arm on a C points straight up.
--the steering arm on the front axle of a B is on the left wheel king pin, the steering arm on the front of a C is under the radiator and points up.
---the B rear axle is 12 inches narrower than the C from wheel to wheel. Hub to hub the B is about 52 inches, the C is about 64 inches wide.
--rear wheel on the Bs held on by one center "BIG" nut to the axle, C mounted with 5 lug nuts.
---of course there are exceptions to the above, but this gives you a starting point. I saw a B last summer mounted to a 4 speed CA transmission and hydraulic unit, with the B final drives. go figure?
Farmer Brown
04-29-2002 19:54:41
The B has the arched style fixed wide front and the C usually has the tricycle narrow front (there are a few (rare) adjustable wide fronts). The B was set up to be a one row tractor and the C was a two row machine so the B is narrower than the C in tread settings.
Go to Tractor photos link under Gallery on the left side of this web page and click on Allis Chalmers then choose a B and a C to look at an you will see what I mean.
The C was rated at a slightly higher HP. The CA was a replacement for the C
The serial numbers are just ahead of the gear shift lever.
Richard
04-29-2002 19:49:42
The C is the trycycle row crop, the B was the wide front.
Eldon
04-29-2002 20:45:44
 Re: Re: difference between B and C? in reply to Richard, 04-29-2002 19:49:42
I just bought a C today with the adjustable wide front. I have a friend who has a parts tractor with an adjustable wide front.
steve
04-30-2002 15:05:23
 Re: Re: Re: difference between B and C? in reply to Eldon, 04-29-2002 20:45:44
"most" of the C tractors built wer narrow front end. There were a good number built with the wide front end, most of these were "adjustable" on the C. The B was always wide front, no narrows. "Most" of the B had the fixes wishbone front end, "some" were the adjustable unsed like the C, these with adjustable front axles, also had the 5 lug bolt rear hubs instead of the "big nut" in the center.
Eldon
04-29-2002 20:39:28
Bryan Smith
05-01-2002 06:06:41
 Re: Re: Re: difference between B and C? in reply to Eldon, 04-29-2002 20:39:28
The distance between the final drive casings (inside to inside):
B - approx 33 inches
C - approx 45 inches
Easiest way to tell in some cases (even though different finals/trannys/etc. have been used for repair on occasion. Recently saw a B sold with a C replacement tranny - had a C serial number on it but was a B everywhere else.)
