D-17 throttle troubles
Pudgy36
04-24-2002 20:29:59
my friend as a 1967 D-17 that the throttle is having problems getting stuck wide open. we cant decide if its the carb. or the gov. any sugestions on what to do would be greatly apricated. thanks
Duey (IA)
04-24-2002 21:17:31
 Re: D-17 throttle troubles in reply to Pudgy36, 04-24-2002 20:29:59
Pudgy 36,
Remove the small cover (4 bolts) forward from the distributor, on front of the engine. This is the governor cover. Governor spring may be broke or governor weight could be broken. If the weight is broken, find all of the parts. Broken parts like to hide behind the cam gear on a ledge. Accessed by removal of the front timing cover and oil pan. A broken part going through the gears can do MAJOR damage. Duey
Dell
04-26-2002 09:04:57
 Re: Re: D-17 throttle troubles in reply to Duey (IA), 04-24-2002 21:17:31
Thanks, Pudgy, my D-17 all of a sudden started screaming when I had it on idle. I'm still using it but the throttle really doesn't work. NOW I'm gonna look at the governor doohickey and see if I can find the problem. Scarred the bejeebers out of me.
