Allis chalmers M
Brian Stewart
04-24-2002 12:27:21
I figured out that I have a allis chalmers M. I do have a couple of questions. It does not have a starter on it but it does have a shaft for a hand crank. Does anybody know if they make a conversion kit for a electric start? Also were these crawlers run by a magnito?
Brian in CA.
04-25-2002 09:03:07
 Re: allis chalmers M in reply to Brian Stewart, 04-24-2002 12:27:21
Thanks to Stan, John in OH and Steve in N.J. Also thanks to Darrell in MN who has helped a bunch.
stan
04-24-2002 21:57:40
If you need a starter you might want to keep a watch on ebay. There was one a while back on their sight. As was mentioned before there is a special tapered bolt holding the starter in. Try to find this if you can.If you have a lathe you can make one. I think the bolt is a 5/8-11. Make sure the bolt is long enough for a lock nut.
John (OH)
04-24-2002 15:14:04
Brian as far as i know mine has a mag and the starter is on the left setting in the seat and looking forward also parts are almost impossible to locate the starter I have does not flange bolt there is a hole in the bellhousing and the there is a bolt to keep it in place hope this helps you I have found a man in Ill. that stocks all kinds of engine parts also this is the same engine as the model U and UC tractors
Steve in N.J.
04-24-2002 18:40:03
 Re: Re: allis chalmers M in reply to John (OH), 04-24-2002 15:14:04
Brian,
According to my data book, there were three different types of Magneto's used for the M. The Eisemann GL-4, the Bendix C-4 & the Fairbanks/Morse FMK4B. Also it said a 6 volt Auto-lite MAB-046 starter w/lights was optional equipment on the M. Hope this helps. Steve
