WD45 oil pump
Harold
04-22-2002 08:34:33
Is it recommended to replace the oil pump when putting new bearings in after grinding the crank? A new one is almost $600.00 and the dealer said he has only sold repair parts for one. Just wondering what other people think. Thanks Harold
Dave Grubb
04-22-2002 12:46:10
 Re: WD45 oil pump in reply to Harold , 04-22-2002 08:34:33
I don't have my repair manual handy but there are some blueprint specs that you should check to see if your pump is in or out of limits before you put it in. The areas I can recall are the pump wear plate, the tip clearance for the gears against the housing, and the drive shaft bore size. Best to get a repair manual and check.
