New tractor ???
markp
04-21-2002 19:17:48
I have found a salvaged B I cant make out the serial number yet but I did see only five didgits apparently making it a 38 model. Hand brakes,hand crank and all, but it does have a hydraulic pump. It doesnt run but it has numerous "parts" on it my question now is it worth 250 dollars.
steve
04-22-2002 19:56:48
 Re: new tractor ??? in reply to markp, 04-21-2002 19:17:48
parts are worth over $250. probably has the old BE engine, not the CE so the HP is a little lower. not having electric start is a little drawback to most people. If you are looking for a tractor to restore, this is a good start, but will be expensive, dont think you will get by cheap. A base tractor that runs but looks poor, old tires, is about $600-$700 at the local auctions. Keep that in mind.
Walt F in jaxn Tn.
04-21-2002 20:35:36
look over in the auctions at the 1943 a c "b", look under "tractors". auctions are at the top left under the heading "market place"
markp
04-22-2002 15:33:28
 Re: Re: new tractor ??? in reply to Walt F in jaxn Tn., 04-21-2002 20:35:36
Hey was all those zeros ment to be dollars or pecos
