Fuel float
alliswd
04-21-2002 17:58:21
the fuel gauge float on my tractor is saturated with gas that it no longer floats. any ideas on how to fix it.
Tom
04-21-2002 18:31:52
 Re: fuel float in reply to alliswd, 04-21-2002 17:58:21
Stick a stick in the tank until it hits bottom, pull it out and you will see how much fuel there is in the tank. Works depenably and is easy to fix. Can by used on many different tractors, is cheap.
moonlite
04-23-2002 02:38:57
 Re: Re: fuel float in reply to Tom, 04-21-2002 18:31:52
Gotta Be Kiddin'!!!!! Must try sometime!
dave
04-22-2002 04:31:29
just fixed a new float on my d-15 go to the hardware store get new cork drill hole for rod dip in shelac and dry twice put cork on rod seal cork on rod with j-b weld re-install to gas tank and fixed.
