WD/WD 45 governor
Tom
04-21-2002 16:20:29
Does anybody know why AC put an oil line to the governor on 45s? And where does it oil inside the governor? Am considering adding such a line to the WD I am working on when I get to oil lines. I know, I know, the WD I am doing has run for thousands of hours the way it was, just thinking of upgrading the way AC did though. They must have had a reason for changing after all those WC and WDs.
denny
04-25-2002 14:27:59
 Re: WD/WD 45 governor in reply to Tom, 04-21-2002 16:20:29
Well, this is my wild guess. Back in the old days, tractors used oil every day. Every day, oil was added to the tractor and ran down the through the gears and governer on the way to the pan. As materials improved, oil consumption was reduced and oil was less frequently sent down that path. With the WD-45, AC engineers may have decided not to rely on the splash method and decided to pump a little oil in there continuously. I think oil also reaches this area from bearings on the govenor shaft.
Regards,
Mike (MI)
04-22-2002 09:14:29
If it's anything like my WC, (very similar I'm sure) it is to oil the thrust bearing and the surfaces that slide in there. I have my WC governor completely disassembled at the moment. The original owner added a line to this one to keep it from wearing out as fast, but it's still completely worn out.
Tom
04-22-2002 16:46:54
 Re: Re: WD/WD 45 governor in reply to Mike (MI), 04-22-2002 09:14:29
I think that oil added anywhere that dripped on the weights would be sprayed all around and lube everything, may do it, can always put a plug in the hole and remove the line if I don't like it.
Thanks for the response.
