Re: final drive
steve
04-20-2002 20:32:39
mark, i bet the brake locked up. if you want to be safe, raise the rear alxe on that side 2 inches and roll the tire by hand forward and reverse and listen. see if you hear anything. if not, it is probley o.k. Dave, i think you have a nick to chipped tooth on the bottom big gear, thats why you hear it once per tire revolution. jack up the tire a couple inches, roll the tire and listen, i would take off the sheetmetal pan below the final drive case and look at the gear. Bet you have a chipped tooth. You might be able to polish the edges with a small grinder wheel and forget it. use 90 we gear lube in the final drive, takes a little less than 2 quarts. change the other side while you are at it. thats the bearing lube back there.
markp
04-21-2002 05:20:39
 Re: Re: final drive in reply to steve, 04-20-2002 20:32:39
I'll try that thanks
