Company Logo (800) 853-2651 Shop Now
Wd hydraulic pump
montey
04-20-2002 18:31:21
I have a wd and last year installed a 3-pt hitch. The two pistons leak a little, but the main problem is in the pump (or what ever it is called). The part that the hoses attatch to (next to the battery) leaks like there is no tomorrow. I have taken off the two bolts that attatch it to the thing below it. My father has had the tractor from day one and says that he has never taken it apart. Is there supposed to be a gaskit between these two parts. I have tightened it down as tight as I can without breaking the bolt but it still is leaking like a waterfalls. I can not tell if it is leaking for here or from the movable part that goes up and down that allows the fluid to move the pistons. Any help on this matter would be greatly appreciated.
Duey (IA)
04-21-2002 07:22:57
 Re: wd hydraulic pump in reply to montey, 04-20-2002 18:31:21
Montey,
There is a picture of the hold position valve on my web page and it shows the O ring seal.
Duey
joel
04-20-2002 21:18:06
an "o"ring i think but would have to check the book
