AC D-15 Power Director Lube.
Z-man
04-20-2002 06:31:49
What should I use? Old stuff is the color of coffee with cream. Can't be a good sign. What might be wrong? Seems to work ok. Thanks for any help.
Craig MO
04-20-2002 17:47:13
 Re: AC D-15 Power Director Lube. in reply to Z-man, 04-20-2002 06:31:49
Your oil has water in it most likely from condensation. Drain and refill with good hydraulic oil like AC 821 fluid
Z-man
04-20-2002 19:14:48
 Re: Re: AC D-15 Power Director Lube. in reply to Craig MO, 04-20-2002 17:47:13
Thank You, I will do.
Bryan Smith
04-22-2002 12:26:54
 Re: Re: Re: AC D-15 Power Director Lube. in reply to Z-man, 04-20-2002 19:14:48
Check out my webpage under tractor specs - I have the D15 Series II listed with fluid types and capacities from the original manual, as well as the current recommendations hwere I have obtained them so far.
