Old Case found
kevin
04-19-2002 11:40:36
I've located an old Case tractor-gas, 4 cylinder. It's missing some sheet metal and the magneto. Front rims are rusted through and the rest of the tractor is rusted. I don't know what model it is--(maybe a CC)--there's a date on the block 10-23-35. Is this thing worth restoring? Are parts available? If I can't get a magneto then there's no sense in moving forward. Any advice appreciated.
Kevin
Try asking...
04-19-2002 12:27:20
 Re: Old Case found in reply to kevin, 04-19-2002 11:40:36
...your question over on the Case board. There are a lot of Case guys that might be able to give you some answers.
Tom
04-21-2002 14:40:46
 Re: Re: Old Case found in reply to Try asking..., 04-19-2002 12:27:20
If you want to get it going you will in time. Check out the transmission and rear end though.
