Spoked wheel repair for WC
Chris
04-17-2002 10:49:13
Has any one out there tried to weld new 24" rims to a spoked wheel on an unstyled WC? I have this incurable notion that I can fix anything if I keep trying hard enough. Any similar experience will undoubtably eliminate some of the pain.
Butch (OH)
04-17-2002 13:53:12
 Re: Spoked wheel repair for WC in reply to Chris, 04-17-2002 10:49:13
Chris, One problem I see is the rims for the round spokes have a much deeper drop in the center than any modern replacement rim will have so you would have to add to the spokes to reach the new rim. I believe that new rims are around $100 per each. A decent pair of round spokes should be $200-$350 depending on how decent and who has them. If it was me I would do a little searching for a set of bargin originals first. If it trips your trigger to save the old wheels from the scrap guy, fix them. I do things like that myself.
Chris
04-17-2002 19:44:37
 Re: Re: Spoked wheel repair for WC in reply to Butch (OH), 04-17-2002 13:53:12
They're flat spoke. I'll come up with something by the time I fix up both the WC's I just bought. Of the 2 complete tractors and one skeleton, there's one good rim. And it ain't original. Like I said, It's an affliction.
RGR
04-18-2002 15:51:05
 Re: Re: Re: Spoked wheel repair for WC in reply to Chris, 04-17-2002 19:44:37
We had a WC with flat spoke that had been cut off and put on rims. Who ever welded the spoke to rims did not do a good job. The wheels wobled and wore out the wheel bearing every so often.
wc
Tom W.
04-17-2002 12:35:15
If they are factory round spokes, I would try to cut the old rim to where you don't disturb the factory rounds. They don't look as good welded to the rim.
Chris
04-17-2002 19:36:54
 Re: Re: Spoked wheel repair for WC in reply to Tom W., 04-17-2002 12:35:15
They're flat spoke. Should be aesy to add to if needed. I like your idea though. If I salvage the area where they attach it would be a lot easier to allign.
