56 wd45
Dave
04-16-2002 08:42:39
wondering if there is a way to adjust the oil press on this tractor. some of the early John Deeres had a lock nut with a set screw u could adjust the oil press with-does this wd have that feature ?
Dave Grubb
04-17-2002 06:47:00
 Re: 56 wd45 in reply to Dave, 04-16-2002 08:42:39
If your oil pressure gage is stock the needle should be on the 'O','R', or 'M' with the engine at normal operating temperature. This equals 6, 9, or 12 psi respectively. Be sure the metal tube sticking up from the oil filter mount is in place. They will occasionally come out and get tossed away with a filter. If your oil pressure gage is an after market gage it be about a 20 psi max reading gage.
Ron
04-16-2002 19:20:27
You may raise the oil pressure some by restricting the oil flow thru that sorry excuse for an oil filter.....!!!!
JMS/MN
04-16-2002 15:39:22
Check the book , but I think there is a nut, about 1" size, on the right side of the engine near the steering shaft, with washers behind, that can adjust oil pressure.
Tom
04-16-2002 17:52:44
 Re: Re: 56 wd45 in reply to JMS/MN, 04-16-2002 15:39:22
Yes, it is something like that. Remember though that you only want 10 to 15 tops psi though. It is the only large nut on the side of the block that doesn't hold something on, really a plug with a hex head.
joe
04-17-2002 04:01:02
 Re: Re: Re: 56 wd45 in reply to Tom, 04-16-2002 17:52:44
Yes, thats right the oil press. regulator spring cap is on the right side of the block near the bottom. Large capscrew plug...can't miss it. You can either replace the worn spring or shim it. Also don't forget to check that the plunger behind the spring can easily travel in the bore.
