Re: Build it Cat. 1 or 2?
Farmer Brown
04-15-2002 19:10:49
Suggest building it Cat2. That way you can hook to implements that are either Cat 1 or 2 in the future. For Cat1 implements bushings are available to bush up to Cat 2. If you build the hitch Cat1 then you are limited to only Cat 1 implements.
The kit I have is a Cat2 as far as hole sizes are concerned and I think the others are also. The numbers you are quoting are all Cat 2 numbers.
The only one that won't work for Cat 1 is the 32" width. Need to be able to go into 27" for Cat 1.
