I need a wiring diagram for ac wd45 please
Craig Carey
02-09-1999 17:36:48
Does anyone have a wiring diagram for a ac wd45
I really need one bad none of the manuals i have contain this piece of info a rough sketch will do
thanks
Mark Vanderburg
02-19-1999 03:31:04
 Re: I need a wiring diagram for ac wd45 please in reply to Craig Carey, 02-09-1999 17:36:48
I don't know how to find a diagram or draw one, but if you are haveing trouble I may can help. I just had trouble with my battery going down all the time so I went and got a new alternater. I hooked it up wrong and it wouldn't work. I added an extra line from the alternater. There is only supposed to be one wire from the switch box to the side of the alternater(blue if like mine) and one going to the back of the alternater(red). The blue goes to the switch and the red to the starter I think. If this doesn't help I'll check back in a couple of days and see if you are still having troubles
John W
02-13-1999 07:09:01
I found WD-45 manuals with good wiring diagrams at my local library. If that isn't an option for you, e-mail with the details of what you're looking for and I'll find one for you.
