Bleeding A WD Hydraulic system
LC in Bama
04-14-2002 15:11:37
What is the preferred method of bleeding the hydraulic system on a 48 WD? Where do you bleed it from to get all the air out of the system and the lift cylinders?
Dave K.
04-19-2002 13:13:22
 Re: Bleeding A WD Hydraulic system in reply to LC in Bama, 04-14-2002 15:11:37
They are self-bleeding. Even if you open and drain the whole system, rams, hoses, sump etc , refill and by raising and lowering a few times they will self-bleed. The manual states this and we have had WD's for over 50 years so are experianced with it. I just did this with my 1948 WD.
Dave
David T (MO)
04-15-2002 09:14:27
Raise the lift and shut down the tractor. Then loosen the packing nut on either cylinder until oil drips out. Tighten the nuts back down until drips stop and drop the lift. (If the packing nuts are too tight, the lift may not drop.) You're done.
