Ignition swap ?
HedgeHog
04-13-2002 18:29:27
I'm going to pick your brains again: A WD45 and a 170 have a 226ci.motor is the 170 a 12 volt or 6 volt? if it's a 12 volt,could I use
ignition parts [points,condenser] in a WD45? I would like to change to 12 volt on my WD45 without using a voltage reducer for ignition DAVE
Duey (IA)
04-13-2002 20:25:48
 Re: ignition swap ? in reply to HedgeHog, 04-13-2002 18:29:27
HedgeHog,
I have some information on my web site that might help you. Duey
david l. wilson
04-13-2002 18:51:11
the points and cond. are probably the same on both,if you don't want the external resistor get a 12v coil that has an internal resistor, it works good,you can get one at about any local auto parts house. good luck david l. wilson
