My WD45 is stuck in 3rd gear...
Pete
04-13-2002 15:47:28
I got my WD45 stuck in third gear this morning. How to get the Shift lever off and how do I get back to neutral? I have fixed this problem with my farmalls but I haven't had the chance to do this on my Allis.
Craig MO
04-13-2002 16:20:36
 Re: My WD45 is stuck in 3rd gear... in reply to Pete , 04-13-2002 15:47:28
Same as on farmall only instead of taking out pin in shifter take snap ring out of cover after taking boot off. When you pull shifter out of cover be careful not to lose the two square dowell pins one the sides. Take long bar and line up shifters and put put back together.
Duey (IA)
04-13-2002 16:18:47
Pete,
The shifter problem is probably due to wear in several places. You can access the problem by removing the rubber boot on the shift lever. Then remove the snap ring etc. and the lever can then be removed.
You will now be able to look down on top of the shifting forks.
With the shift lever or a long screw driver you can now move the shift fork back into neutral.
Wear points are the groove on the "ball" of the shift lever, the square headed pin that rides
in the groove, the ball itself, the socket, the tip of the lever and the top notch of the fork.
Repairs will have to be determined by you after you have evaluated the wear points. You
may only have to work on one or two things. If the shift lever twists around it would indicate
a worn pin and groove. Over size pins were available at one time and the groove would have to be re cut to fit the oversize head or a new groove cut on the opposite side and a new pin put in the hole on the other side of the shift tower. The oversize pins also required the removal of the "soft plugs" in the side of the tower and the pin hole redrilled to the oversize shank of the oversize pin. Sometimes a big machine washer under the snap ring will help.
The tip of the shift lever can also be built up with a welder and then reshaped. The same can be done with the forks but that will require the removal and disassembly of the shift tower.
Duey
Pete
04-14-2002 06:42:59
 Re: Re: My WD45 is stuck in 3rd gear... in reply to Duey (IA), 04-13-2002 16:18:47
Thanks for the help. I really appreciate you guys for helping me out on this one.
Thanks again,
Pete
