WD-45 What's it worth??
Haas
04-13-2002 11:54:11
I'm and IH guy, but am looking at an Allis WD-45 gas and wondering what is a fair price. The WD-45 is original, needs paint, grill and hood are straight and it has fairly good fenders. Runs good with no smoke, but seems to run faster than it should at high idle. Wonder if governor is out of adjustment or something needs repair. Owner says a spring in the linkage is missing. Has snap coupler system and the hydraulics lift the disk plow (not AC) that comes with it. The hand clutch will not release, so there is a problem there. Tires are average and usable, but one rear is leaking calcium solution at the valve. Rim looks solid, but likely some repairs needed, hopefully minor. First order would be to remove rims and fix the tire problem. Any info on pricing would be appreciated. Area is Northeast TN, Southwest, VA. Thanks.
