7060 --D-21
CBL
04-12-2002 11:44:03
I have a 7060 #5300 and would like to know the difference in the motor in it and the motor in the D-21 S2 with the 3500 series engine. Are they as reliable? Thank you CBL
John
04-14-2002 22:36:48
 Re: 7060 --D-21 in reply to CBL, 04-12-2002 11:44:03
Also the black belly 7060 had more oil gallies for piston cooling. The head had some changes to accept the inner cooler in the water jacket/thermostat housing. The 7060 also used a different style ring on the pistons. But I have seen a 7040 engine put in a 220 without a problem, and know of a 7040 that has all to works of a 7060 on that 426 block. Most parts are interchangable.
CBL
04-18-2002 13:29:30
 Re: Re: 7060 --D-21 in reply to John, 04-14-2002 22:36:48
John-- Do you mean the black belly 7060 is different than the red belly 7060 like mine, or the D21? Thanks for the reply, CBL
Craig MO
04-12-2002 16:52:04
The biggest differance is the 426 block in the 7060 has more or heavier webbing in the block.
