Narrow to wide front?
HedgeHog
04-12-2002 11:31:33
could I take a wide front from a WD/WD45 and mount it on a WC? the frames look the same. thanks: Dave
hedgehog
04-13-2002 18:12:15
 Re: narrow to wide front? in reply to HedgeHog, 04-12-2002 11:31:33
thanks for all the responses I'll try it and let you know what happens.
JMS/MN
04-12-2002 21:44:52
I used to think that this was possible, but then I remembered my Dad buying a saw frame from one that would not fit the other. Seemed like the width of the frame was 18" on one and 19" on the other, but after 40 years.....the memory fades. As long as the frames are not a different width, I don't see why it would not work. I think the bolt dimensions are the same. Just tape it first to make sure.
JMS/MN
04-13-2002 09:30:11
 Re: Re: narrow to wide front? in reply to JMS/MN, 04-12-2002 21:44:52
Correction- the memory came back a half-day later. I believe the attempted switch was between a JD and the WD.
Brian G. NY
04-12-2002 20:14:47
I took the measurements off my brother's WC frame and compared them to my WD. All the dimensions are the same including the bolt hole locations. even the steering shaft bushing is located in the same place on the frame. I never did such a swap, but my conclusion was that it would be a "bolt-in". Seems I recall this discussion a year or so ago and some people had indicated they had actually put a WD WF in a WC.
Tom
04-12-2002 20:37:28
 Re: Re: narrow to wide front? in reply to Brian G. NY, 04-12-2002 20:14:47
I have seen a WC with a wide front, but I don't know what was done to do it. I agree I don't think it is more than a "bolt in" though.
Brian G. NY
04-13-2002 06:53:03
 Re: Re: Re: narrow to wide front? in reply to Tom, 04-12-2002 20:37:28
The WC could be had with a factory WFE, but it was a simple arched, non-adjustable cast iron one like a very heavy duty "B" non-adjust. axle. The WD axle would be much easier to find as the WC axles are fairly rare.
LL
04-13-2002 18:54:02
 Re: Re: Re: Re: narrow to wide front? in reply to Brian G. NY, 04-13-2002 06:53:03
The last year or two of production the WC was available with adjustable wide front just like the WD.
