Spanner Wrench
Gary
04-12-2002 05:50:00
I want to buy a spanner wrench to take apart the 3 pt lift hyd. cylinders on my AC D-17 but don't know where to get one. Can anyone help me out?
Thanks,
Gary
Tyler(WA)
04-12-2002 07:42:07
 Re: Spanner Wrench in reply to Gary, 04-12-2002 05:50:00
I got mine from my Industrial Hydraulic Supply store. There should be one in your Yellow Pages.
You sure can't get by without one if your cylinders call for it.
Craig
04-12-2002 20:07:00
 Re: Re: Spanner Wrench in reply to Tyler(WA), 04-12-2002 07:42:07
I took a 1/2 inch piece of flat bar about 12 inches long and made mine. I cut out notch for the rod end and cut the other end down on both sides for a handle. Drilled 2 sets of holes just like the original AC tool and then drove in solid roll pins letting them stick through about 5/16 of an inch. One side does D-17 the other does 190 & 200's. Works great and its a lot cheaper than one off tool truck.
Brian G. NY
04-13-2002 06:56:57
 Re: Re: Re: Spanner Wrench in reply to Craig, 04-12-2002 20:07:00
I've made a couple of spanner wrenches like you, Craig. I drilled and tapped holes and installed cut off Gr.8 bolts. Your way is quicker; if I do another, I'll use your method.
