B machine
TractorMike
04-11-2002 21:02:33
Hi all, I was wondering, could I run a one way acting hydraulic cylinder like on a pull type bush hog with my B's hydraulic pump without the oil level getting to low? Thanks, TractorMike
markp
04-12-2002 06:00:52
 Re: B machine in reply to TractorMike, 04-11-2002 21:02:33
I run a six inch chief cylinder on my three point hitch that is plugged into the side of the pump with a vent plug in the opposite end of the cylinder and I don't have a problem. I guess if you had a long cylinder you could run low.
TractorMike
04-12-2002 08:31:44
 Re: Re: B machine in reply to markp, 04-12-2002 06:00:52
Thanks, TractorMike
steve
04-12-2002 17:37:21
 Re: Re: Re: B machine in reply to TractorMike, 04-12-2002 08:31:44
mike, i also use a cylinder on the B. the cylinder is off a CA, about 2 inch diameter and 8 inch stroke. it works real good on the level. i have run low on oil when going down a 15 degree slope. I am thinking of putting a 3 inch long pipe nipple in the transmission fill port and putting 2 extra quarts of oil inside. If it dont churn the oil up too bad, i plan to leave it that way.
