Re: Will D17 pistons fit in a WD block.
Ron
04-09-2002 05:33:55
Yes, they fit...
Be sure to check the lower Block Webs for cracks...Nearly all have a crack between #1 & #2.....it does not render the block unserviceable---it just will need to be repaired, then Seal the lower Block and Sleeves well ( Coat the Lower inside Water Jacket W/ Aviation Sealer, or Permatex....GLYPTOL would be the best, but may be hard to find...It is made to coat Electric motor armatures, and is popular for coating inside racing engines...
LL
04-12-2002 19:39:58
 Re: Re: Will D17 pistons fit in a WD block. in reply to Ron, 04-09-2002 05:33:55
Not to seem defensive but the great majority of WD blocks that I've ever had apart were not cracked at all and the majority of the cracked ones were cracked at the top only which is usually caused by the engine having been over heated at one time or another. This crack at the top has never given me a leakage problem. The only time I've ever seen a crack at the bottom webbing is from freezing which usually also caused a crack on the external side of the block.
