Model C rear wheel studs?
Dana
04-08-2002 18:53:39
I just noticed that the right rear wheel on my model C has studs that are mounted in the axle, however on the left rear, there are bolts (head on the wheel side with nuts on the back side of the axle flange) holding the wheel hub on. This isn't the way they were from the factory, is it?
I suspect that I just discovered some creative engineering that was performed many years ago as this tractor has been basically untouched since the 1960's. Can any of you other Model C owners confirm this?
Tom W.
04-09-2002 09:50:33
 Re: Model C rear wheel studs? in reply to Dana , 04-08-2002 18:53:39
The C had studs on the rear. If you took the studs out, you could put bolts in their place.
