D-17 Hyd.
Ron K. Stucky
04-07-2002 07:08:18
I just put a JD loader on an early D-17 Allis. The Hydraulic pump is worthless for the loader. I was told I need to put a pump on the front of the engine. I was also told I need a special adapter from the crank to connect the hydraulic pump. Any idea where I can find a used adapter? Yes, I know I will have to change the valves on the loader because JD valves are closed center valves.
Thanks for any information you can give
Ron
Nellie
04-14-2002 03:42:54
 Re: D-17 Hyd. in reply to Ron K. Stucky, 04-07-2002 07:08:18
I read where the adaptors are available. I got sick of looking and brought my D17 Pully to a machine shop and had an attaching piece and shaft made. If you try a search you may find more information. One nice person posted pictures of his front pump project. I'll see if I can email his pictures. Also try looking at posts around this date RE: D-17 front hyd. pump parts REED 1/5/00 10:33:34 PM It talks about the adaptors you need.
JMS/MN
04-07-2002 14:39:19
Check with salvage yards. The adapter bolts on to the front of the crankshaft pulley to drive the pump, which mounts in front of the steering casting. There is a nationwide chain of yards called Parts Express. Call 1-800-248-9263 for the Michigan yard, they can give you numbers for the other yards or put your request on their hotline.
