B keeps going and going
markp
04-06-2002 21:08:39
My B doesn't cut off anymore except running out of gas when I close the valve. The on off switch has never worked and I could choke it down with the throttle but not anymore. any hints or advice
Steve / BB Custom Circuits
04-08-2002 14:52:45
 Re: B keeps going and going in reply to markp, 04-06-2002 21:08:39
Mark,
If your machine is equipped with a mag, it's probably the push/pull kill switch is inop. (or toggle if equipped) I have new mag push/pull kill switch kits in stock which mounts in the OEM ammeter box. Comes with new switch, wiring and connectors. E-mail me if ya need one....
steve
04-07-2002 18:53:32
mark, if the tractor has a magneto then there is a very small threaded terminal sticking straight out to the right by the throttle shaft. there should be a small wire on this terminal. if you take a wire and touch the terminal and then touch the tractor frame with the other end, the tractor will die. Just like a lawn mower with a mag type ignition. It is not uncommon for the mag to burn the contacts on the little toggle switch and it will either be permanently off or on. Follow the wire from the mag to the switch and make sure it is connected. make sure the switch is grounded to the tractor frame. If evrything is connected, then the switch is bad.
----if you have a distributor and a coil, then it is just the opposite. the switch disconnects one of the wires to the coil. lift a wire off the coil (small wire, not the plug wires) and the motor will stop.
Trevor
04-07-2002 06:06:26
Maybe start with either removing one wire from your switch or using a jumper and shorting to ground, depending on whether you have a coil and distributor or a magneto. This way you will know if it is the switch or a wiring problem.
Bob
04-07-2002 10:22:10
 Re: Re: B keeps going and going in reply to Trevor , 04-07-2002 06:06:26
I am a new owner of an Allis Chalmers.
I would like to purchase an owners manual but not sure which one. It is model B(1952) and the serial no. is B118262. If you could help or know of someone that can I would really appreciate it.
Thanks Bob
DanD.
04-07-2002 13:09:31
 Re: Re: Re: B keeps going and going in reply to Bob, 04-07-2002 10:22:10
I'm sure you can go right to your nearest AGCO dealer and order an owner's manual. If you don't know who your dealer is, go to www.agcocorp.com and use their find dealer function.
JMS/MN
04-06-2002 21:21:58
Replace the switch that is not working.
