D15-D17
Gordon-(TN
04-04-2002 23:49:32
I a'm posting for a man in west tn. that lost left leg in a accident,he needs a tractor with hand clutch, thinking in the line of D15 or d17 if anyone can help his phone# is 731-584-6591 likes the Allis chalmers. thanks for any help Gordon-(TN)
JMS/MN
04-05-2002 21:22:06
 Re: D15-D17 in reply to Gordon-(TN, 04-04-2002 23:49:32
Two years ago I broke an ankle in a fall and was on crutches for two months. For spring planting I made up levers that clamped to the clutch pedal on three tractors- JD 4240, 4430, and 4450. If you e-mail me an address, I'll be glad to send pictures of the device. Very simple to build, and cost only a few bucks apiece. The general idea could be adapted to other tractors.
Bob
04-05-2002 18:27:39
gordon with all do respect,i dont think an allis will work for him as they still have the foot clutch.the only true hand clutch is the older model john deeres.
JMS/MN
04-07-2002 14:49:19
 Re: Re: D15-D17 in reply to Bob, 04-05-2002 18:27:39
The JD hand clutch would be fine, but the brakes are on each side of the tractor, rather than together on the right, so one missing a left foot could not use the brake. However, the WD hand clutch could be disconnected, and that same location, with a bit of ingenuity, could be utilized through the appropriate linkage crossing over forward of the battery box to the foot clutch. In fact, if the right rear wheel were left out at least one position and the right fender reworked a bit, enough room could be gained to mount a new lever and linkage to the clutch and still retain the hand clutch. I think a similar plan could be worked up with the D series.
Craig
04-05-2002 21:39:31
I agree with Bob, you still need to push on the foot clutch to put the tractor into gear.
WD hand clutch works
04-06-2002 12:18:52
 Re: Re: Re: D15-D17 in reply to Craig, 04-05-2002 21:39:31
I can shift my WD from any gear just using the hand clutch.
