Compression, I think?
Sheldon
04-04-2002 16:05:06
I am not an engine mechanic, but I'm trying to learn. My question is this:
How would an engine behave if the spark plugs were so loose I could unscrew them with two fingers? I'm assuming it would effect the compression? What would it do?
greg
04-07-2002 18:31:05
 Re: compression, I think? in reply to Sheldon, 04-04-2002 16:05:06
It would probably start and run well, but a faint "ticking" may be heard while running due to the loss of compression, which would be very slight due to the speed of the piston rising in the bore.
Bryan Smith
04-08-2002 06:11:14
 Re: Re: compression, I think? in reply to greg, 04-07-2002 18:31:05
I had a mower once that would not *start* unless the plug was loose. Turned out that the points were shot. The loose plug meant a poor ground, which allowed the spark voltage to build up more, which could then get a spark across the bad points and fire the plug. Just a tidbit that had me puzzled for a while ....!
