B front spindle/kingpin
Bus Driver
04-04-2002 15:45:03
Been helping a (definitely non-mechanical) friend work on a 1950 B with arched, fixed width front axle. The right spindle/kingpin had severe wear on the lower kingpin bushing and some wear on the kingpin. New genuine AC bushing helped, but right wheel still has wrong camber. Have access to a lathe large enough to turn the kingpin, the original centers are still on the part and I have a MIG welder. Considering welding the worn areas on the kingpin and turning to original size. Tractor will not be used often or heavily. Should we proceed with this repair or is the welding/machining a bad idea. If bad, what is the main reason? Anyone with experience doing this and your results? Thanks. Incidentally, the engine in this tractor is superb! Cannot imagine a better engine for a tractor this size.
brian
04-05-2002 15:22:14
 Re: B front spindle/kingpin in reply to Bus Driver, 04-04-2002 15:45:03
if it's what you want instead i'll sell ya a pair, got an extra set laying around here that i can part with.
greg r
04-04-2002 17:41:54
We mig welded and turned two kingpins
for a 39 b with the same problem. It
worked.
Dick L
04-04-2002 17:13:13
MIG or TIG welders will both work well. When you turn it back down it would be best if you have a grinding attachment for the lathe. If not you can still get a good finish with a file and emery cloth. Go slow with the welding.
Okieboy
04-04-2002 18:50:29
 Re: Re: B front spindle/kingpin in reply to Dick L, 04-04-2002 17:13:13
I have done several of them like that.Heat the entire spindle before you weld it. Let it cool slow then do your lathe work. A tool post grinder does give a better finish but like Dick said a file and some emery clothe will work ok. Bob
