What B engine oil pump parts are usually worn?
Bryan Smith
04-03-2002 13:30:54
third party image
When I put in a clutch in my B in a few weeks I want to check over the engine oil pump. I know to re-surface the cover (part #2 in the diagram) to help with oil pressure. I'll also have a gasket (part #3) on hand. Any other parts I should have on hand when I do this? I'd hate to break the tractor in two and have to wait on a spring to put it back together...!
Thanks in advance.
mark dingbaum
04-08-2002 11:44:33
 Re: What B engine oil pump parts are usually worn? in reply to Bryan Smith, 04-03-2002 13:30:54
Hi,
When you get it apart, check the pin in the back of the cam that drives the oil pump (fits into the slot near arrow 5 in your drawing). My 'C' pin was very nearly sheared off, and the holes in the cam were egg-shaped. I drilled it bigger and put in a larger hardened pin. You'll probably have to remove the cam to replace the pin, I'm not sure.
good luck,
mark
frankie
04-07-2002 09:21:24
replace with a new pump-youwont regret- they are cheap-
Roy
05-20-2003 04:19:43
 Re: Re: What B engine oil pump parts are usually worn? in reply to frankie, 04-07-2002 09:21:24
Hi
Iam looking for an oilpump for my B as well. Do you know where I can get one cheap?
Thanks
Roy
Dick L
04-04-2002 07:15:23
Bryan, Open up the pump and check it out. If you run into a problem you can send it to me and I will repair it and send it back. All it will coast would be the postage and parts. You will be able to do it your self I am sure, But I will do this if you run into a problem. Not to worry!
brian
04-03-2002 16:06:03
cover, vanes, springs, and the ball all seem to be the most used. had mine apart and dressed the cover only. it was the only thing bad, and my tractor sat outside it's whole life till it come to me.
if you need parts in a hurry check with sandy lake imp. they ship quickly and have most parts in stock
Bryan Smith
04-04-2002 07:20:44
 Re: Re: What B engine oil pump parts are usually worn? in reply to brian, 04-03-2002 16:06:03
Thanks for the kind advice (and for the offer, Dick!). I appreciate the insights - just don't want to have it torn apart in my buddy's shop for a week or two waiting on parts.
