180 allis help!
james hansen
04-02-2002 08:51:15
Please help me figure out what's happened to my 180. First I found chunks of steel in my power director valve, then my steering hand pump, suspected the hyd pump came apart, but I dissasembled it last night and founfd nothing. Next I pulled the pan where the suction line and return line come together, found the screen broken which explains how the steel got past that point, now here's where I'm lost, In the power director compartment area there's a little hole for oil to drain into this pan i removed I stuck my index finger in there and found chunks of steel, and also could feel something like a big washer floating around in there what could have happened in there, when i pulled the tracxtor in there every thing worked, the pto was working all of the gears were working the power director was working, but slipping at low rpm,s, but im suspecting that the steel in the valve is why it was doing that I'm planning on splitting the tractor tomorrob but looking for some one to tell me what to expect, thanks
james
