Wd-45
bob C
04-02-2002 07:36:22
I sent my head out for rework (valve job and valve seals) now, after installing shiny new looking head, i have oil, yes oil running out of my exhaust port. What can be wrong? thanks Bob C
Johny Deer
04-05-2002 10:41:36
 Re: wd-45 in reply to bob C, 04-02-2002 07:36:22
I would say you have blown head gasket or either leaky valve seals
Ron
04-02-2002 11:03:03
I am pretty sure I put " Umberella type" seals on mine....Nothing to mal-function w/ them... Like the ones that are on Ford 390's... Cheap, too. Check to see that the spring clips are re-installed on the valves...they keep the valves from falling into the cylinder, if you break a valve spring...
James (MO)
04-02-2002 10:42:23
Another possibility is that one of the valve seals is leaking. Oil runs down between the valve stem and seal. One or more seals could be defective or installed improperly. One way to determine that would be to squirt oil around each exhaust valve/valve seal interface and see if oil gets into the exhaust port. My $0.02!
Ron
04-02-2002 10:24:56
Are you sure there was no amount of oil in a cylinder that could have been pumped into the exhaust port.?? I have found that using Chrysler 318 valve retainers increase the seat pressure...helps heat transfer...avoids some chance of burned valves... That oil came from somewhere...Let us know what you find.!!! Other leaks are common after replacing the head...seepage on the sparkplug side is common, for a while...then there is that flat plate, held down with 2 head bolts.....!!!! That plate drives me nuts...!!!!! !! I find that "Bowing" it a small amount, toward the center- then taping the outer 1/2 of the holes down, helps spring the center down, when it is tight, to hold the gasket tight....
