Re: Allis B Rear end Oil
Author |
steve
04-01-2002 19:46:41
Trevor, lets make sure we are talking about the right case. When you say you had water in "the rear end" i am assuming you mean the differential case behind the transmission?? if so, the water came from rain around the transmission lever. the transmission case, the differential behind it, and the PTO housing behind it are all connected internal. you fill them thru the transmission fill plug on the left side by your foot. it takes about 2 gallons and should be a good trans-hydraulic fluid, 20wt. you can get this at the farm store, or wal mart. There are three plugs to drain the system, one under the transmission, one under the differential and one under the PTO. you are draining the same oil, at three levels. If you are talking about the final drives (the little tin pan) at the bottom of the drop box, setting inside the rear wheels, then yes you need 80 or 90 wt gear lube in them. you must remove the pans and clean out the old oil. after reassembly you add oil thru the 1/2 inch pipe plug. i havnt seen a final drive with water in it too often. last of all, yes you can do exactly the same thing with the CA.
Brian G. NY
04-01-2002 20:38:51
Re: Re: Allis B Rear end Oil in reply to steve, 04-01-2002 19:46:41
I believe the B, C & CA have only two drain plugs; one under the tranny and one under the PTO hsng., unlike the WDs & WD-45s which have 3 plugs (5, if you drain the hydraulic system). The Bs & Cs hold 7 Qts with the PTO option, and the CA holds 8-3/4 Qts.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Restoration Story: 1951 Farmall H - by The Red (John Fritz). I have been a collector of Farmall tractors since 1990 when I first obtained part of the family farm in Eastern Indiana. My current collection includes a 1938 F20, 1945 H, 1946 H, and the recently purchased 1951 H. This article will focus on what I encountered and what I did to bring the 1951 NEAR DEATH Farmall H back to life.
... [Read Article]
Latest Ad:
2 old Dodge Pickup Trucks not running mostly complete early 50s flathead 6cyl stepside box side entry hoods Price 1200 both.
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
