Mower widths for a d-14
DougM
03-31-2002 21:16:48
According to specs I've seen, the d-14 may just be able to handle a 6 foot mower. But I'd like to hear from people who've had experience with 5 or 6 footers about what they think. I'd mostly be cutting grass and blackberry mix with some woody vines, mostly less than an inch in diameter.
Thanks,
Doug
Bryan Smith
04-01-2002 06:00:29
 Re: mower widths for a d-14 in reply to DougM, 03-31-2002 21:16:48
We used a 6 foot Bush Hog single blade mower (snap coupler hookup) on a D14, WD45, and D15 Series II interchangeably over the years. The D14 didn't have the power of the other two (43 and 46 hp, respectively), but handled it fine in normal pasture mowing in third gear high range. Thicker stuff required going slower. Figure about 2 acres per hour if it's an open field with not a lot of obstructions.
Farmer Brown
04-03-2002 09:13:37
 Re: Re: mower widths for a d-14 in reply to Bryan Smith, 04-01-2002 06:00:29
Power question aside, I think you would not be happy with a 5 foot because it would be narrower than the tractor. Couldn't mow close to anything or even cut your own tracks.
